Advice spraying Cardinal Luthierlac http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=45379 |
Author: | Joe Beaver [ Wed Mar 18, 2015 5:45 pm ] |
Post subject: | Advice spraying Cardinal Luthierlac |
Hi, I will be attempting my first Nitro finish in a few days. I have chosen Cardinal Luthierlac. I plan to use epoxy filler under the finish. Should I put a coat of vinyl sealer over the epoxy and under the finish or spray the nitro right on the epoxy? Also, any suggestions as to spray schedule would be greatly appreciated. |
Author: | Jim Watts [ Wed Mar 18, 2015 6:22 pm ] |
Post subject: | Re: Advice spraying Cardinal Luthierlac |
I would use the vinyl sealer. It'll assure good adhesion |
Author: | James Orr [ Wed Mar 18, 2015 8:33 pm ] |
Scuff the epoxy well before spraying their sealer. After spraying a few coats of sealer, scuff it very well before spraying the lacquer. I had a lot of adhesion issues before getting in touch with Mac. He really impressed the importance of scuffing on me, which wasn't an issue when I used McFadden. |
Author: | kencierp [ Wed Mar 18, 2015 10:05 pm ] |
Before I started using Zpoxy as a filler I communicated directly with tech support at Pacer and I was assured that their product was compatible with nitro lacquer. I use vinyl sealer as part of a complete finishing system and would recommend that practice regardless of the pore filler that is used. |
Author: | Joe Beaver [ Wed Mar 18, 2015 11:25 pm ] |
I did order their vinyl sealer. When I read the write up on lmi's page I got the impression that you didn't have to scuff the vinyl sealer if you sprayed the top coat within a half hour. Apparently that is not the way to do it. |
Author: | James Orr [ Wed Mar 18, 2015 11:36 pm ] |
I had to strip the finish twice because it peeled like a flaking sunburn when I tried to level. I'd scuff just for good measure. Sent from my iPhone using Tapatalk |
Author: | Joe Beaver [ Thu Mar 19, 2015 12:51 am ] |
James, I think I remember you posting something about that. It would be a real bummer. After all was said and done, how did you like the cardinal? |
Author: | kencierp [ Thu Mar 19, 2015 6:46 am ] |
The information I got from Pacer was in regard to their Zpoxy "finishing resin" if using System Three or other I'd check with the makers. The beauty of a compatible nitro finishing system is that each layer of chemical "burns" into the previous layer. Personally, I simply would avoid using coatings that lay "on top" each other --- with scuff process or not. |
Author: | James Orr [ Thu Mar 19, 2015 11:02 am ] |
Joe Beaver wrote: James, I think I remember you posting something about that. It would be a real bummer. After all was said and done, how did you like the cardinal? I don't have the nuance to compare the final result to the McFadden I've used before, but it seemed slightly trickier to use due to those issues. I think it's a great to still have an option for lacquer though. |
Author: | kencierp [ Thu Mar 19, 2015 11:39 am ] |
I am pretty sure Seagraves "Macfadden formula" instrument lacquer is still being sold -- I thought I saw it in the SM catalog. |
Author: | Joe Beaver [ Thu Mar 19, 2015 11:53 am ] |
Ken I thought Seagrave bought the rights to McFadden. But when I google Mc fadden lacquer it comes up with a full Lawerence McFadden product line inclusing Nitro with Seagrave on the bottom of the page. One big happy family now? |
